주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
질문 마감됨
So, Why is my iPhone 5C not turning on?
okay, so i have been in Ifixit quite a few times and i have had broken screens both times for my Iphone 5c. The last time i have went in they told me they couldn't fix it after they have repaired my screens and things, my iphone wont turn on, can you tell me what i should do ... what you can do ? ..
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
is this your battery working(http://www.laimarket.com)
Im not sure if it is or not, it just wont turn on. I've tried everything
댓글 달기
답변 2개
가장 유용한 답변
does it not turn on or is it just no display?
try plugging it in to itunes, and see if your computer will pick it up.
also does the cable go all the way in the charging port?
when you plug the cable in to charge you shouldnt see any silver parts.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I tried all of that, nothing is working. it just wont turn on, it used to Vibrate when i plugged it in, but it doesn't do anything anymore. my computer didn't pick it up, and i made sure my charger was in all the way i left it on charge for about 30 /45 minutes .. and still nothing happened. what do you think it is ?
댓글 달기
Take to repair place and have them open the iPhone and simply disconnect the battery for a minute, then reconnect it. After this you may need to charge the iPhone. See if this helps. If not you may need a new front screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Is it going to cost me money to take it in and have them open it up and disconnect it ? and i might try this tomorrow . thank you.
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 286
