My picture is very dark
좋은 질문 입니까?
hpimidwest, it is possible that it is your bulb.It could mean that your lamp is old (4000-5000hrs) but it could also be your ballast. As the lamp gets older, it requires more voltage to spark or ignite. If you still have a picture, just dark/darker you are a bit in a catch 22 situation. You can buy a new bulb and hopefully that will resolve the issue, but if it does not, you would have to replace the ballast. You may end up purchasing both. There are numerous variation of ballast and bulbs. We'd need the exact model number to help you out further.
해당 답변은 도움이 되었습니까?
my tv is okay, after a little while, its getting dark, and nothing at all...it has sounds, what is the problem? thanks
One of the bulb needs replacement if not calibration. If you are able to take apart, you can test which one is out. If you can't take apart and it's under warranty, get it replaced for free.
Good luck.
해당 답변은 도움이 되었습니까?
what bulbs are you talking about
no picture has sound wont stay on
해당 답변은 도움이 되었습니까?
drahming 415 you posted a question as an answer to a different question. Your question can now be found here want say on,no picture,has sound
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,724
댓글 1개
Serial # B19G3CKL501709L
MODEL # HLS5087WX/XAA
Matthew Spencer 의
