주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Replacement screen has Vertical Gray Lines
Just replaced my wife's iPhone 6 screen with one from iFixit and it has vertical gray lines. I tried reseating the cables. No dice. Tried unplugging battery for 30 seconds. Checked connectors for bent pins. Don't see any.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
This is normally because of a pinch in the ribbon cable that has damaged data lines or the LCD cable was flexed at the LCD and broke connections.
I have also seen this in rare occasions if the digitizer cable is not properly seated.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
thanks for your reply.. so does that mean this digitizer is hosed and i need a new one?
I just had that issue when I was replacing my screen and found the problem to be one of the connectors from the digitizer not being properly seated.
댓글 달기
Either the above answer by chriswku03, or it's because the units enclosure is bent out of shape.
It is a pretty thin piece of aluminum after all, so it doesn't take a whole lot before its bent, especially if dropped.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I plugged in the original cracked one and it worked fine. iFixit sent me a new unit that works perfectly. Great customer service!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
timktran 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 1,341
