My device cannot turn back on
Hi.. i use Huawei Ascend G7 about 6 month. I want turn on my device after suddenly off it cannot turn on anymore. Can you help me?
좋은 질문 입니까?
좋은 질문 입니까?
estimado amigo lo primero que puede ocurrir es que la bateria como comunmente decimos los tecnicos esta muerta o sea sin carga necesitaras acudir a un sat y que te reanimen la bateria. la bateria pierde toda su carga si no se utiliza durante un tiempo.
espero haberte ayudado
해당 답변은 도움이 되었습니까?
If you try and charge it and there is a red light flashing, it means that the battery is over-discharged, you should probably go to the phone shop and they can help.
해당 답변은 도움이 되었습니까?
sfdgkjvbnwsv vfweijsfvnw svusfvhsfvkmdfb afoiwefngcv wo sdfkosgsfc nrgoiwretjhdhb sdlkfhSDF neorfghferg sfdpgjszfdh ndlkfgjhwarg bzdb 9sgjdflbm,rgjkn ghkl;gnkgh7gn5fghemlgknsdigndgbndgbv fxhnhnfbn
translated :)
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 1,086
댓글 1개
Same problem of my phone
Banie 의
