power base giving off a burnt plastic smell
After blending with the nutri bullet there is a burnt plastic smell coming from the power base.
좋은 질문 입니까?
좋은 질문 입니까?
You may contact Nutribullet Customer Service Department at 855-346-8874 for assistance on using the product or warranty service. (Mon– Sun, 9am–8pm Eastern Time). You will be required to provide the barcode/serial number located underneath your Motor Base
해당 답변은 도움이 되었습니까?
Mine is not under warranty but smoke is coming from thebase unit
The blade assembly can fail and does not rotate freely, then you get additional friction overloading the motor, hence the smell and smoke.
The blade assembly fails regular,
해당 답변은 도움이 되었습니까?
Karen, could be the motor bearing or the motor winding etc. Unless you take it apart using these guides it will only be a guess.
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 38
30일 전: 132
전체 시간: 50,902
댓글 3개
I just bought a nutri bullet and After blending with the nutri bullet there is a strong burnt plastic smell coming from the power base. Why?
sandhanamkasi 의
Hi I have the same problem, as soon as I started there was a spark and burnt smell. Was your problem resolved? What should I do?
Mansi 의
I had that too. Took it back and have the same problem
cecille heath 의
