주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s logic board EMI SHIELD
Hello Everyone...
I cant connect my iPhone to my computer and problem is with USB control IC chip and I was wondering that if it is possible to solder the EMI Shield back into place with a heat gun after removing it .
Please someone help
Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
John Smith, I am not quite following you with this. Yes you can resolder the EMI shield, but use a soldering iron versus a hot air gun. You will have better control over the heat than you would with a hot air gun. My confusion is with the shield and the connection of the USB control IC....Any problem with that IC will not be related to the EMI shields
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Thank you for the quick response. Your right but i have to remove the EMI shield to get to the USB control IC which is located near the processor.
Can you please tell how to resolder it back into place
And thank you again for responding
Depends on how you took the shields off. If you used a hot air station to remove it, you should be able to resolder it at the same solder points. If you did not and you cut it off or removed it by other means, you could try to mate some points or leave the shield of altogether.
Thanks for your help i've got my answer
John Smith, how did you get the EMI shield back on? Oldturkey will leaving the EMI shield off altogether affect how the phone works?
댓글 달기
귀하의 답변을 추가하세요
John Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,098
