주요 콘텐츠로 건너뛰기
PowerPC G5 프로세서를 사용하는 iMac G5는 2004년에 처음 출시되었습니다.
453 질문 전체 보기
Startup problem HD fail OSX install fail
The machine was working fine, then the screen appears something like a closing curtain with faded colour from top to bottom. The screen is faded and appears a black box at the center with 2 or 3 different languages saying that I have to restart the computer.
I restarted it and then cannot boot it up again. The screen only appears with the clock spinning and after around 1 minute, the fan keeps making the jet sound and never stops. From now everytime I turn it on, the fan still keeps the jet sound.
The machine not only cannot turn on, try to hook from an external HD also nothing happen and it freeze by itself.
Things I have tried and nothing help:
1- Ran Warrior, Drive Genius, Disk Repair all through CD or by hooking up with my powerbook G3 and nothing happen. All of them says the same thing, cannot repair the HD or the volume. Fail fail fail.
2- Tried to reinstall the whole OSX 10.4, it install half and then says again installation failed.
About the HD, sometimes I can see it and sometimes cannot when i hook up with other mac.
Any idea what's going on?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
If you have another drive install it and see if the problem goes away. If it doesn't try swapping your memory. Select your G5 Model and the the guide to replace the hard drive and the memory. Good luck Ralph
iMac G5
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
+ If it's starting and running from your DVD's then it's definitely the hard drive. Look on the bottom of the stand for your exact model and we can direct you to the repair manual.
I tried the AHT from the installation disk and it didn't pass the logic board, so i think the main problem is the logic board.
댓글 달기
귀하의 답변을 추가하세요
3macs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 961
