주요 콘텐츠로 건너뛰기
모델 A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 또는 3.5 GHz Core i7 프로세서, ID iMac14,2
340 질문 전체 보기
instal 4790K Processor in Mac Intel 27" late 2013 (ME089)
hello!
can i install intel core i7 4790K processor from Imac 5K
as i know all components in new imac is the same?!(not consider logic board and LCD)
by the way, TDP core i7 4790K is 88W. but heatsink is the same?
so, it can be done?
Update
its not a problem for me. a have all need tool and skils to open imac.
i'm not shure that 4790K is started in old logic board.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
If you do attempt it let us know what you discover. Good Luck!
Did you try this? I'm interest in hearing the results.
Processor is not start at the system. I think efi is not suport processor id
댓글 달기
답변 1개
선택된 답변
First here is the specs of your iMac's series: iMac14,2.
Here are the CPU choices:
  • 3.2 GHz i5 (i5-4570)
  • 3.4 GHz i5 (i5-4670)
  • 3.5 GHz i7 (i5-4771)
As a reference heres the i5-4670 chips specs on Intel's ARC site: i5-4670 Processor and here is the i7-4790K Processor. Note the socket supported: FCLGA1150, so it appears to be physically possible. The only difference is the TDP 84 vs 88 Watts.
Even still the systems firmware may not allow you to make the change. Keep in mind this would be a very large undertaking! You're a trailblazer here I don't know of anyone going that far.
Are you sure you want to take the risks here? Also the 'Thin Series' iMacs are harder to open and you do need the correct tools as you can easily damage the display if you are not careful.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi,
The systems EFI firmware doesn't support other CPUs not used in that specific iMac generation.
Only 2012 CPU and only 2013 CPUs can be used within logic boards of that exact generation. So, a 4790K for all 2014 boards, 4771 for all 2013 boards and 3770 (not 3770K) for every 2012 board.
I’ve tested all boards separately.
Oh, that hurts! so... anyone tried any workaround to solve firmware issue? I guess is almost impossible to modify firmware sucessfully.
댓글 달기
귀하의 답변을 추가하세요
cslbox 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 18
전체 시간: 2,889
