주요 콘텐츠로 건너뛰기
이 안내서를 사용하여 모든 제조사 및 서비스 제공 업체의 전화기를 수리해보세요.
73578 질문 전체 보기
What is digitizer in cell phone parts?
Can anyone tell me the different between digitizer and LCD with digitizer? Are they the same thing? If you show me the pictures of them I would be very grateful!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Martin Benitez, the LCD is what shows the images. the digitizer is clear and is what allows your phone to work by touch. Most often it is adhered to the LCD. LCD with digitizer assemblies are in general easier to install. You do not have the hassle of trying to remove the old digitizer from the LCD. You will also need special tools to remove the digitizer from the LCD as well as applying special adhesive to "glue" it back on. For more info, take a look on here.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
@oldturkey03, can you check your link? It seems to be redirecting me to random locations rather than the interesting-looking title I see in the hyperlink.
@dadibrokeit darn, it pooped out after only 7 years :-) I think I may actually still have some literature on that. I'll repost.....
댓글 달기
There are differences in the design structure of third-party iPhone screens produced by Chinese factories, which can be divided into incell, oncell and outcell.
Incell's touch panel is embedded between the liquid crystal layer and the TFT substrate,
oncell's touch panel is under the top polarizer,
outcell's touch panel is above the top polarizer and under the glass lens.
https://taoyuanparts.com/blogs/news/diff...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Martin Benitez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 774
