주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
212 질문 전체 보기
How do I remove coins pushed into the optical drive?
My four- year -old has just admitted to pushing one or more coins into the optical drive of my desk top. Is it worth using a flat knife on it to ease them out or should I remove the drive and then take it apart to get at the coins? Help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
It's better to remove and open the drive. These SlimLine drives are rather fragile. Pictures of a hairclip lost in a MacBook drive here. Also the work of the owners little daughter. Where would be the Mac repair business without the little ones? ;-)
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
You should be fine just using this guide to remove the optical drive, after which you can simply pick out the coins with tweezers.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Depending on how far in they are, you might be able to get them out with something hook-shaped. This might also help: Optical Drive Disc Removal Technique, or Foreign Object Removal
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
matt846 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 6
전체 시간: 5,338
