주요 콘텐츠로 건너뛰기
다양한 Canon 디지털 및 필름 카메라 수리 및 분해 안내서.
1797 질문 전체 보기
Why half of canon vixia - legria mini X screen is bleached?
i turned my camera one day and half of the screen is fine and the other looks bleached.
does anyone know the reason ?
Image - (kinda hard to see in the Image)
http://i.imgur.com/1ZTVt8b.jpg
http://i.imgur.com/pGV3vLs.jpg
Update
This is the canon Vixia mini X screen part number
(transcribing to be search engine friendly)
1580014262 5130729485C ROHS
TM027CDH19
00DFK09A05F10MP11311022
This screen is a TIANMA brand 320*240 res screen.
the closest one i found was
http://www.panelook.com/TM027CDH22_TIANM...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Jeff soc, that looks like a bad LCD. Of course you want to make sure that all the cables are still properly attached, but ultimately I'd be prepared for a new LCD.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
That's what i thought, where can i source a replacement ?
canon asked 160$ to only inspect it. probably another 100$ for a replacement screen.
if i can find a replacement module it would cost around 40$ and i don't mind doing it myself.
i've repaired cameras before.
here an idea maybe the powershot N screen (which is superior to this one ) will work, its a close fit 2.7" vs 2.8".
what do you think ?
Let's see if we can find a proper screen. I doubt that the N screen would work
took it apart to see if maybe it something with the cables. unfortunately, it's not but i have the screen part number now. maybe i can find a replacement.
dumping all the pics i took maybe someone could use it in the future.
http://imgur.com/a/Al34v
hello Jeff, did you ever find the fix to your camera?? I'm experiencing a similar problem as well. I would be greatly appreciate if you can share where you purchase the parts from. thank you
Wayland Asbury, better later then sorry i guess.
i've never managed to source parts for it. no. :/
댓글 달기
귀하의 답변을 추가하세요
jeff soc 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 1,014
