주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
touch screen does not respond
Why does my touch screen not respond every time I touch it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 5개
My screen has only 1 area where it doesn't responde
Mine similar issue just touchscreen buttons on bottom that make it so I can switch apps
Same issue. Amazon hopefully will send a replacement. Switch to Samsung.
Help my kindle fire hd won't touch anymore and it's touch screen
My toch screen is frozen with a yellow line around
댓글 달기
답변 1개
가장 유용한 답변
mikecornerstone, could be a bad digitizer. Of course, you do want to try a soft reset first Soft Reset:
Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
Your reboot screen should appear when you release the power switch.
Wait a minute or two to give your device time to reboot
Turn the Kindle back on.
After that you most likely will have to replace the digitizer. Here is the guide for it
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
mikecornerstone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 21,107
