주요 콘텐츠로 건너뛰기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
Backlight works, but no display!
Okay, here's the rundown.
A1502, purchased in March 2014, has suddenly created a pretty nasty problem.
Went to boot one day and *chime!* but no screen. Apple logo on the back lit up, backlight was obviously working, but ZERO display workings.
Okay, so I plug in an external monitor. Nothing. "HDMI signal not detected." Okay, so I do the Googles, read the reddit, etc etc. Reset NVRAM/PRAM, reset SMC, no luck. Try booting Command+D Diag. mode, and output on external monitor! However, white progress boot bar hangs at 1/2way for 3.6 hours. So I Safe Boot (Power+Shift). Finally, I can use my external monitor! I can get into my mac and mirror displays, so that I can offload my data. Great.
I know the int. screen isn't working-- that's not the discussion.
Here's the question: When I boot normally in clamshell-closed mode, external monitor works perfectly. But the second I open the lid (i.e. use keyboard) EVERYTHING GOES BLACK AND TURNS OFF. Then, I must boot into safe mode to use the mac again! And the cycle repeats itself... What is the culprit here? Iris video card, Logic board, loose internal connector, or all of the above? Is the internal display issue and this issue related at all?
P.S. Congrats for getting this far. I know the writing is dense.
Thank ya much,
Nick Flint
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 4개
I have exactly the same issue with the same model (A1502). Are there any "soft" solutions for this problem? What about your macbook Nick? Did you fix it?
+1 same issue
same, anyone? motherboard problem?
Its the LVDS (display cable) problem, try reconnecting the cable again
worked for me but replace lvds if it dosent
댓글 달기
답변 9개
가장 유용한 답변
Had the exact same problem as you after my MBP had fallen off the bed.
Had a completely black screen - not even a backlight. Tried tapping on the casing near the display cable and pushing the black bar in at the back of the laptop but it did nothing. Tried resetting NVRAM/PRAM - nothing.
I realised that I could log in and suddenly the keyboard and Apple logo lit up and the backlight was working so I figured there was something wrong with the screen. Connected it to an external display and got nothing but then I tried booting it whilst pressing cmd + D and it worked on the external display, however it completely shut off as soon as I tried to log in.
Eventually realised I was going to have to open the case to see if the display cable was damaged. I've never done this before so was a bit nervous but I ordered a screwdriver set from Amazon and waited a couple of days. Followed the guide posted above to open the case and located the display cable. Tried wiggling it a little and screwed the case back together and frustratingly it did nothing. Almost gave up at that point and was resigned to the fact that I'd have to take it to get repaired.
However, I gave it one last go except this time I disconnected the battery and the display cable and plugged them back in. Put it all back together, turned it on and BOOM! Screen turns on, everything back to normal! So relieved that I've fixed it!
Thanks for all the advice in this thread, you're all lifesavers!
Rob
이 답변이 도움이 되었나요?
점수 10
댓글 9개:
Rob,
Thanks for this answer. I currently have the same problem on my MBP. I cant see the entire thread here. Do you have a link for where the guide you used to troubleshoot the display connection can be found? Thanks.
Derek
I can't remember exactly which one it was but I think it was this one:
MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement
Just skip steps 7-10 as it's not necessary to remove the fan/antenna cables/iSight camera. Unplug the display cable and plug it back in and see if that works.
Hope it helps!
Rob
Thank you!I dropped mine today and it was working fine after, but a couple hours later the screen went black (back light still on). Tried setting pram, smc and got a a display on the external monitor, but was hanging on boot just like OP. Got it booted in safe mode, but still nothing on the primary display. Just for kicks I gave the corner of the laptop a good smack (while powered down) and shockingly it booted find after that, like nothing ever happened. Just to be safe I opened it up, disconnected the battery and display cables and reseated both. Took about 10 minutes (include 8 minutes to find the right screwdriver). Thanks again to Nick for writing up the problem so well and to Jay and Rob for answers that worked for me. I was moments away from driving to the Apple Store!
Thanks a lot Rob!!!
I owe u a beer or something. It worked. Wifey is happy too. :)
Dropped my macbook and no display. Booked a service to an authorized shop but saw this thread few hours before I go. I just had to get the correct screwdrivers at my local comp shop. And followed the steps on the comments below. I’m so surprised that I actually made it to work. :) Thanks again. Saved me time and money. Cheers
-Mark
Savior! It really works! The same problem and guess what, it was made by the Apple Genius Bar staff when I looking for a fix for screen coating issue. They can't fix this problem and just saying sorry again and again, what a $@$*!
댓글 4개 더보기
댓글 달기
ATT!
I tried all of the soft reboot solutions and nothing worked.
I dug a little deeper and found information about the display cable and that it can become loose.
I simply tapped on the bottom of my MacBook a few times in the position of the cable and suddenly, there was life!
이 답변이 도움이 되었나요?
점수 3
댓글 7개:
Oh my goodness for the life of me I tried all the resets too. My symptons where that on startup the screen is black but with the blacklight on and the logo in the back would stay on even after closing my macbook pro 13 retina.
I simply did what you said, tapped the corner where the display cable is attached to the board ( left side next to power connection) a few times to release some frustration whilst still caring for thing, then I powered it on and everything was back to normal, yay! Now Im curious if it really is just loose, and how can I fix this or if I can get apple store to tighten the connection.
Thanks for the suggestion!
MAAAAATE!! I've been searching for help on this for a good couple of hours now slowly accepting the fact that I'm gonna have to open up my MacBook and have a good rummage around, when I saw this and thought ah what the !&&* and it 100% worked!! Give the top left hand corner a little squeeze just like Sal said and if your cable is a bit loose it should sort it!! This is literally the only time I've found one of these super simple solutions to a technical problem that seems really serious so thank you so much for flagging it up
Worked for me too!
Don’t know if you’ll see this four years later, but you’re awesome! Searched through dozens of threads and tried everything... basically resigned myself to only using an external monitor, but a couple of taps and the display is working again.
Just curious, anyone know how does this works out in the longterm? Does the display error become more frequent? (First time for me was two years ago, and then last week, and then again just one week later...)
Does this tapping method eventually become ineffective?
Worked for me. After trying PRAM reset without sucess.
Does this tapping method eventually become ineffective, should i go to a apple shop ?
Paulo
댓글 2개 더보기
댓글 달기
This doesn't sound like a video card issue, it sounds like a short circuit somewhere (maybe a blown cap or resistor? no way to tell without inspecting). Shutting down when you open the lid would indicate to me a safety mechanism when the unit detects a short or power spike trying to engage the primary display, and one of the involved chipsets terminates the power to avoid permanent damage. I don't believe it's a loose connector, because that isn't normally so predictable a result.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I know this is an older thread, but, I've been seeing this more often lately in the shop. I CAN say that (in this specific case, repeatable.) all the standard reset procedures & tricks are attempted. In SOME cases, it seems the PRAM (guess it's the SPI/:PC Reset.?? Whatever, Apple calls it the same thing still... CMD+OPT+R+P), causes a single screen flash, then nada... Hope to update tomorrow. ?? Good Luck All.
댓글 달기
Hi guys,
since I was so happy that i found this post as it also helped me to fix the “backlight-only-issue” on my Macbook pro (ate 2013, 13” Retina, A1502) I just wanted to share some notes how it work for me.
So, I also faced the issue only backlight was working but no graphic/screen at all. Chime was there and ext. display also worked.
I simply opened the back of my Macbook unscrewing the ten pentalobe screws (TS4 / 1.2mm). Next, I just wiggle/press+pinch that cable around the connector you’ll find on the top/right (s. att. picture) and my display starts working again. Took me 5 Minutes to fix and it’s still working since a few weeks now.
Thanks for your support + best regards
FuXX
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Nick,
First: try disabling any power save and sleep feature in the System Settings.
Second: initiate a First Aid scan on the hard drive.
Third: Download any available updates from Apple.
Fourth: While you are in Safe Mode close the lid and open it again and see if the problem replicates.
If the problem does not replicate in Safe Mode it might be good to perform a fresh install after you back up your data.
This will tell you whether you have an issue with hardware or with the software.
I would love to hear the results of the steps above.
Thank you,
Michael
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Of course, if your screen is black, you can't do any of the things you suggest, unless of course you are able to connect to an external monitor, however, in my experience none of these things work. If, after resetting SMC, PRAM/NVRAM, you still have a black screen, it's most likely the cable. You may get by with cleaning the contacts, re-seating the cable from the display to the motherboard. However, if that doesn't work, try cleaning and re-seating the other end that connects to the display. This is more involved and may require detaching the screen to get access to the cable connector (underneath the wifi antenna).
댓글 달기
I have a 2017 MacBook Pro 13 inch, I got it 2 years ago and last year I had to get the keyboard fixed. It was free because of the apple care. Apple care already expired and my backlight display, the flex gate, got ruined. I won’t pay 600USD + to get if fixed when they already admitted the 2016 MacBooks came with the same defect. Has anyone had the same problem and gotten it fixed for free?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
(hey, this is a late reply, so it might be too late, and I have a mid-2014 macbook pro, so it might be completely different problem.)
Anyways I took my laptop into a Genius Bar and they took it to the back to check it. It came back out 10 minutes later fixed, although they wouldn’t explain exactly what they did. The temporary “repair” was free, but permanently fixing the problem apparently requires the display to be replaced, for 600$ something. She said if it happened again I could come in again for free.
ah, btw I don’t have apple care.
댓글 달기
Do you still have this problem? I found a video somewhere on youtube that shows how to at least turn your laptop on and backup all the data you need. Me myself have been living with this kind of solution from late 2017.
So my HDMI port is not usable anymore, repair shop assuming it's my graphic card that cause this problem. The keyboard backlight works fine, the capslock button works fine. All that happens is the laptop screen is not showing anything after the macbook chime sound heard.
The step is turn your macbook and make sure the keyboard backlight is on. Put your laptop on couch or bed (any soft surface to cover all the hole on the backside of the laptop). I usually cover MacBook with blanket or jacket. Do this for about 30 second and then open your laptop, if the screen is not on yet repeat the step.
Sometime it takes up to 10 times to open and cover your laptop again with jacket. If you think it's not working after a lot of retries then turn off your mac by holding down the power button. You can turn it on again and retry the method above
People said that this trigger your graphic card selection caused by the sensor that detect the heat of your mac (since we covered all the holes with blanket / jacket / put it on soft surface such as bed). How? After you put your macbook on, the fan will always start rotating. The moment when you block the air that are flowing it will cause the temperature to rise and the macbook choose the other graphic card that are working.
Hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Omg mine had the same problem and tried all the commands and then read this article and gave it a good old bashing in the left and omg it worked!!!!!!!!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I tried reseating the connectors or tapping the case but it didn't work.
What worked for me after dropping was to adjust the cable position by pushing it further towards the screen, noticed it looks a little frayed (probably due to the hinge design).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nick Flint 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 108
전체 시간: 51,040
