주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.4GHz, 2.7GHz, 또는 2.8GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
질문 마감됨
Help identifying component on Logic Board
Hi there,
I would need some help trying to identify a corroded component close to the backlight connector, which is overheating constantly, in order to track my logic board issues:
Thanks in advance,
Mark
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
Also, board is 820-3332.
I can't really read the numbers on it. As you can see from the pictures, there is some corrosion in there which doesn't help at all.
It seems I found the schematic for it (page 66):
http://support.karat-service.net/Laptop/...
Yes you did indeed:-)
I'll let you know how it goes, yet being a newbie doesn't help much :D
댓글 달기
답변 1개
가장 유용한 답변
that is reference designator Q7530 which is a 649136PBF. It appears that this is a difficult part to find any data about. I'd try and get a donor board and harvest that. It'll be cheaper than purchasing any individual part and would provide you with more spare parts in case you'd need them. Anyhow, this is not to say what or how things failed and always consider that there are further issues. This is just to identify the part as good as possible.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thanks oldturkey03. It seems hard to get a spare part for this one.. any recommendations? Cheers
Go with a board that you can use for spare parts.
Thanks a lot :)
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 223
