주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
After Repair: Home button working, Touch ID not
I just finished swapping my screen after two cracked ones and a malfunctioning one. After these three fixes, everything was working perfectly fine (except for the screen on the last two changes; bought from the wrong person I guess). Now, after putting in the newest screen (and having to readjust the cables as one wasn't in all the way, making this newest screen malfunction…) Touch ID is no longer working. When trying to activate it, it sends me to a "Failed" screen immediately after trying. Does anyone know what this problem would be? I've tried readjusting both Home button connections and nothing seems to work. If I did damage it, can you give me a link to the part I need to repair it? Thanks for any help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
You have to use the OLD home button. I f your new screen came with camera and home button already installed, that is usually the case.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
It is. That's the problem.
could you be more precise? what IT IS means - you tried it or it comes with home button?
댓글 달기
Try to reset the touch ID. Your old touch ID data has been disable after screen replacement.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
How'd you go about doing this? Is it something in the OS or the hardware?
Just reset everything. Nothing. Any other ideas?
댓글 달기
Your Touch ID is linked to the device you can't replace with new button without loosing the Touch ID function.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 376
