주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Galaxy Wonder라고도 불리는 Samsung Galaxy W, 모델 번호 i8150으로 식별됩니다.
Will not Hard Reset! HELP
Every time I search for this phone Samsung Galaxy W t679m, I can find the Galaxy Exhibit, but it is not an exhibit, it doesn't say exhibit on the opening screen; it says Samsung Galaxy W.
I need to perform a Hard Reset in order to buypass the lock code; I know holding down Power + Volume Down = Custom OS, but when I hold Power + Volume Up it will show the 'Android Out of The Box' picture, but it will stay like that until it shuts itself off. I have no other buttons on the phone except the touch screen ones that only work when it is on. If I press the menu button (three horizontal lines on the very left) on the touch screen, it will display yellow words over the Android, it says "Rebooting..." at the bottom, and it just shuts off. Am I doing it wrong?
How do I Hard Reset this thing! Thanks in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
The Samsung Galaxy W model is also known as Samsung SGH-i8150, Samsung Ancora, Samsung SGH-T679, Samsung Exhibit II 4G, Samsung SGH-T679M
댓글 달기
답변 2개
Madisen Nish, to hard reset your device you need to follow this steps. Make sure that your Samsung SGH-T679 is Off. Take out its battery for 10 seconds, Then put it in again. Press the volume up button + power button then wait for the Samsung logo to appear then release the power button, then press the home button for 2 seconds. Then use the volume down to navigate and select Factory data reset and wait for the process to be completed. Doing a hard reset will erase all your saved files and application. Also, check on here for more.
Let us know if this worked.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Didn't work at all hopefully it will just start functioning LOL
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Madisen Nish 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 1,368
