Samsung Galaxy Tab S 10.5. The charging port is not working.
The charging port needs fixing. I have had to wriggle it to start it charging but now it's not charging at all. Can this be fixed easily? Is this an expensive thing to fix?
좋은 질문 입니까?
좋은 질문 입니까?
Gavin Dempsey, the charging port for your Galaxy Tab S comes on a flex that combines the USB Charging Port and the micro SD reader. Cost for that is around $10USD . Places like this as well as many others. Toughest part will be to get the back off. The first two minutes of this video will show you how to do that. The image shows the flex on the left side center.
해당 답변은 도움이 되었습니까?
Do you know the part number for this item. I have never repaired and remotely similar and i want to be sure i order the right part.
Samsung part number for that is GH59-13985A
Thank you! I just replaced my battery thinking that ws the problem. It came at 62% charged so I know it's good but it still wouldn't charge. Ill try this.
I replaced my charging port, but broke the connector to the motherboard. Anyone know if this is replaceable and/or where to find the replacement part?
It can be replaced by microsoldering. When you find someone in your region, he should know where to get a part. I use donor boards for that
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 8,233
댓글 1개
Yes there are a number of how to videos on youtube. Don't get ripped off at a repair shop for something easy you can do yourself for under 20 bucks
rebelgator7 의
