주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Pro 1세대는 Apple Inc.에서 제조한 Intel Xeon 기반의 워크스테이션 컴퓨터입니다. 1세대 모델에는 2006년부터 2008년까지 출시된 기기가 포함됩니다.
Fried RAM and Toasted Board
Mac Pro Dual 2.0 GHz 3GB RAM 320 HD
This one has had me busy for a couple of days. Came in with three blinking lights on the power button and kernel panic on start up. After testing for an hour it would not boot at all. The machine had two 1 GB sticks and four 256 sticks. After extensive testing I found all the sticks were fried. Replaced RAM with two good 256 sticks of my own. Switched hard drive to a known good system and it booted to the kernel panic screen again. After testing for another hour it fried my RAM and I get no boot. I ask this question because I don't know if the power supply might be involved and I don't want to replace the motherboard just to have it fried again. I haven't seen a machine that keeps frying RAM before. Suggestions?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 2개
This machine should have diagnostic LEDs. Did you check them?
의 공유
Interesting question--can't wait for the solution. +
의 공유
댓글 달기
답변 1개
선택된 해법
Don't know why Fried RAM and Toasted Board sound so appetising? perhaps i am just hungry!
Hi Mayer,
Yes, i have come across a Computer (server in fact) frying RAM chips. It was a HP ML130G5, the problem was in fact the power supply. I had my workshop guys test the Power Supply and it had a few blown capacitors, this was causing over-voltage spikes.
The surges were running down the RAM Rails and frying the chips!
I would replace the power supply as soon as possible mate as turning it on and off with the supply in it's current state could be slowly damaging the other components such as the CPU.
I am just stating that this was my problem and that's how i fixed it, could be a completely separate problem for you though. If you do get it replaced and it works i'll be happy as RAM frying is an expensive game :)
James.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thanks so much for your tasty answer. A new development was that after being off for 10 hours the machine booted just fine. No RAM lights and I got tone. Put in a blank hard drive and started from the installation disk. Got 90% through the system installation and it shut down. Tried rebooting and got the RAM lights again. Tested the RAM in another machine and it's OK. So I have a motherboard that when heated shows the bad RAM lights.
의 공유
Oh that's a strange one, must be the motherboard after all then, glad you got to the bottom of it mayer!
의 공유
댓글 달기
답변을 추가하세요
mayer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 25
전체 시간: 4,866
