주요 콘텐츠로 건너뛰기
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
855 질문 전체 보기
Mower deck not engaging
i have husqvarna model EZ5426BI mower deck will not engage. Just had the mower serviced than was mowing the lawn and IZT belt broke and was replaced and found the Deck belt had crack so I replaced it and now the deck will not engage
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Generally speaking, when it works until you fix it, you should go back and double check the work you did. Probably got the deck belt routed wrong - go back and make sure you are on the right side of every guide and pulley.
댓글 달기
답변 1개
You might want to check you ingagement lever and see if the cord that goes from the lever to your deck is broke
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bhagwanji Gosai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 72
