주요 콘텐츠로 건너뛰기
Power Mac G4에는 Mirrored Drive Doors가 있습니다.
80 질문 전체 보기
Power On, fans spin up, power light on 1 second then off
I recently acquired a Power Mac G4 1.25 MDD 2003 era machine. Top-notch cosmetics and I had plans for good Mac times here. But, instead my "new" MDD is suffering from this problem: 1) Attach power cable & DVI connection to Samsung LCD display & USB connection to Apple brand full size keyboard and the optical mouse; 2) Touch the power button above the mirror drive doors; 3) the power button illuminates for just 1 second and then immediately goes back off; 4) Fans spin up - low hum at first, and then the full "wind tunnel" effect; 5) no image appears on the LCD display, and the G4 does not respond to any keyboard commands; 6) I have let this G4 run for several minutes, but no change in the power light status and no responsiveness / output. I have reset the PMU, and did perform a full upgrade of RAM to 2GB OWC 333 MHz and dropped in a fresh PRAM battery. I have reseated the NVIDIA AGP graphics card. Looks like a trip to the 1 local Apple Specialist in a large Midwest metro is on tap.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Dave Weaver, looks like a bad processor or logic board. here is what apple says:"
Computer begins to power up, the fan and hard drive are spinning, the power
LED is lit (or the LED goes off when button is no longer pressed), but there is
no startup chime or video
1. Reset the logic board. Refer to “Resetting the PMU on the Logic Board” in this
chapter.
2. Verify all PCI and AGP cards are seated properly.
3. Reseat the processor module.
4. Replace the processor module. Refer to "Before Replacing the Processor" in this
chapter.
5. Replace the logic board.
Update (09/25/2015)
Let's see if this will help you out a bit more
Power Supply Verification
To power on, the computer’s logic board requires a “trickle” power of +5V. If the system fails to power on, first reset the PMU. Then follow the procedure outlined below to determine whether the problem is related to the power supply.
Note:
To verify the power supply, you need a volt meter. When connecting the volt meter leads to specific pins, make sure the power supply remains securely plugged into its connector on the logic board.
The following figure shows the pins and voltage on the computer’s power supply connector. (The color noted represents the color of the wire attached to the pin.)
1. Plug a known-good power cord into the computer. Do not turn on the computer.
2. Connect the black lead of the volt meter to pin 12 of the power supply connector; connect the red lead of the volt meter to pin 14. The volt meter should measure approximately +25V. If you do not get a reading of +25V, recheck the volt meter connections and measure the voltage again. If voltage is still not present, replace the power supply. If you do measure +25V on pin 14, the power supply is likely OK. Go to the next step for further verification.
3. Check the trickle voltage by connecting the black lead of the volt meter to pin 12 of the power supply connector; connect the red lead of the volt meter to pin 1. The volt meter should measure approximately +5V. If you do not get a reading of +5V, recheck the volt meter connections and measure the voltage again. If voltage is still not present, replace the power supply. If you do measure +5V on pin 1, the power supply is likely OK. Go to the next step for further verification.
4. Start up the computer by pressing the power button on the front panel. If the computer starts up normally, the power supply is OK. If the computer does not start up normally, go to the next step.
5. Check to see if the power supply fan is spinning. If the fan is not spinning, replace the power supply. If the fan is spinning, go to the next step.
6. Connect the black lead of the volt meter to pin 12 of the power supply connector; connect the red lead of the volt meter to pin 24. The volt meter should measure approximately +12V. If you do not get a reading of +12V, recheck the volt meter connections and measure the voltage again. If voltage is still not present, replace the power supply. If you do measure +12V on pin 24, the power supply is likely OK. Go to the next step for further verification.
7. Connect the black lead of the volt meter to pin 12 of the power supply connector; connect the red lead to pin 6. The volt meter should measure approximately +3.3V. If you do not get a reading of +3.3V, recheck the volt meter connections and measure the voltage again. If voltage is still not present, replace the power supply. If you do measure +3.3V on pin 6, the power supply is likely OK. Go to the next step for further verification.
8. Connect the black lead of the volt meter to pin 12 of the power supply connector; connect the red lead to pin 3. The volt meter should measure approximately +5V. If you do not get a reading of +5V, recheck the volt meter connections and measure the voltage again. If voltage is still not present, replace the power supply. If you do measure +5V on pin 3, the power supply is likely OK. Go to the next step for further verification.
9. Connect the black lead of the volt meter to pin 12 of the power supply connector; connect the red lead to pin 10. The volt meter should measure approximately +12V. If you do not get a reading of +12V, recheck the volt meter connections and measure the voltage again. If voltage is still not present, replace the power supply. If you do measure +12V on pin 10, the power supply is OK and the testing is complete. You have verified that the power supply is not the cause of the “no apparent power” symptom..
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks for the very helpful response ! Symptoms match EXACTLY my problem with this MDD 1.25 GHz = power button does not remain lit after touch, no startup chime and no video output. So, it's off to the Apple Specialist. Best regards, DW
Best of luck and let us know how it turns out.
Thanks again for the super helpful response here. I carted my 'new' 1.25 MDD 400FireWire tower off to the 1 independent local Apple Specialist.
The young Tech told me:
" Well, I'm pretty sure it's the Power Supply. "
" And, then in the next breath -- BUT it COULD BE the logic board. "
" I've only worked on a couple of these MDD's and I won't be much help with diagnostics here. "
I have actually tracked down a certified used MDD 1.25 logic board and separate daughtercard processor assembly. I'd really like to check condition of the Power Supply before springing for the board and processor assembly.
So, my next step is scouting out any tips on checking G4 MDD power supply operation. Hmm, more searching on iFixit :-) :-)
댓글 달기
I have this problem too and have verified it is the power supply.
What is the part number for the power supply and where can I get one?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
18.11.19 From Uk. (very uk). Not Proof Read Nor Spell Checked. Ive always used win devices starting with 98. I thought i would try fiddling about with a G4 i got free and a digital audio which i bought. Just lately i tried startin em up. The ree one (of course) showed the light on the switch then it went out. Fiddled about with power supp connewctors etc and still same thing. So got new battery and this time monotor showed the grey start up page but then displayed no signal. Tried the reset button but no luck. Too out graphics card and made note of it then refitted but same problem. Have taken out HD abd will try it as second drive in Digi Audio mac G4. Have not yet done voltage checks due to survival issues like police attacks because we have 1000pp evidence of manic corruption throughout UK and Europe. No reply from any estal org incl law. local govt, MPs. police. home office. The coroner service was approached by the use of bodyguards and it produced results. Anyway the Digi audio mac fired up but it has defeated every attempt to get it on to broadband. It was satisfactory on dial up. Cant see an way of removing dial up system or app. Internet explorer seem to half work but not sure as the interface seems clogged up with text which looks a jumble. Have reached the conclusion never to patronise Apple Products ever again. The OS is illogical compared to Wn XP/Vista. I cant see any Reistry in these macs. Also the crazy idea of having Op systs which only work on specific computers is a rip off. Also we found that the graphics boards seem to have no distinct recognition which assoc it to Mac. It was a shock to find out that Apple manipulate the standard bourds which fit windows normally. Of coiurse its all about money. Have noticed that the people who buy macs are ofter or mainly people in art orteaching which of course explains why the system is hopeless. We reckon these things were sold on the weakness of style and had they looked like a Dell Office machine the sales would be very low. We reckon theres a snob value in the Apple Logo. Why an Apple should have status we dont know. How about a banana or Pear PC ? Yeah we know the public are easy to trick but only when charlatans do it to them. Just read the History of US off the maistream and the whole thing is revealed. The shock of finding that the US has been employing secret socialsim whilst pretending you have to stand on own feet was amplified by finding out the the rail owners were given prime land for free. THe owners claimed it didnt matter if they worked people to death cos if god didnt want it then he woulde have intervened. When these clowns died they gave money to corrpt Universities. Want evidence re UKHM Govt. HM Coroners. HM Courts. HM Prisons. HM CPS. HM Bar Council. HM Princes Trust. HM . Health. Local Govt. Sport. Media.Charities.etc. I bet you do. Wonder if Bill Graham meant it when he shouted- Let Jesus into your hearts. How come God didnt protect him+his wife from illness.Some of the Nazis lived to an old age. How come ? Catholics/Scientologist/Jehovas/Chuch Of england./Prtestants./Baptist. How come none reply to questions about 30000 avoid deaths over 30 yrs? If you listen to the small group known a Bill and friends on 38.40 which was orig org by Bob Bellars you might be shocked but that dont change the US does it. Ask us whats behind the reecent shooting in US. Dare you ? Dont think so. What was the most frequent response of public during our 12 yr hike thro London knockin on doors- Its nothing to do with me! So long. Av a nice day.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dave Weaver 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,180
