주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.3GHz 프로세서, 1GB RAM, 5메가픽셀 후면 카메라를 탑재한 7.00인치 1280x800 디스플레이의 보급형 태블릿입니다.
Startup loop won't stop
At first... It was shut down and restart when it connected to internet, and afterwards it gone in a startup loop to the logo and shutdown again.
I cannot stop it or complete start my tab.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개
i have your problem in my tablet can i ask you how you fix it pleas
의
I have the same problem in my device. so far I can not solve this problem. if your problem was solved, please help me? thanks in advance.
의
댓글 달기
답변 1개
가장 유용한 답변
Try a hard reset. Here's a video on how to do it: https://www.youtube.com/watch?v=L2nFwCzf...
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
i've tierd this and it faild "wipe data faild" error : connot get phone encrypt state"
i also tierd flash officail stock room but i couldn"t cuz it keep restarting (usb disconnect over and over) than tried to use adb to flash it but the "usb dubbing " wasn't actived
and no matter i try to installe rom (zip file) or any other package using recovery mode i get this" installation aborted"
의
If you encounter the mount /data error or error mounting data message in the recovery mode of your MTK Android (e.g Tecno, Gionee, Infinix, Opsson, Innjoo etc) phone then your /data or /SD card partitions might be corrupted. To fix this, try the methods below:
Format SD card (If there's a slot for it)
* Remove the SD card
* Format the memory card on a PC (FAT32)
* Slot the SD card back in and boot the phone normally
* Switch off then boot into recovery mode
* Re-try the operation
Wipe data & eMMC
* Boot into recovery mode (volume up + power) and select Wipe data / factory reset
* If the above fails, boot into Chinese factory mode (Volume down + power) and select the option with eMMC in its name
* Reboot the phone
의
thank you the quick answer but ....
there r no sd card on the phone just the internal storage 16GB i guess
pic : http://img15.hostingpics.net/pics/125395...
의
댓글 달기
답변을 추가하세요
wello25 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 25
전체 시간: 7,496
