주요 콘텐츠로 건너뛰기
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 질문 전체 보기
clutch adjustment nissan altima
how do you adjust the clutch on 2002 nissan altima
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
선택된 해법
Donna,
The 2002 Nissan Altima has a hydraulic clutch and it can not be adjusted. The only thing you may be able to do is adjust the pedal travel. There may be a nut with a threaded rod on top of the pedal attachment point under your dashboard.
If the clutch feels funny, try bleeding it. If that is not working, try replacing the fluid. If you still have a problem you may need to replace the clutch.
Regards,
Frank
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Works for me +
댓글 달기
I got a 2003 Altima and and the gear shift is locking up
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
donnalyns1020 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 7,631
