blank or dark screen on dell
When I try to turn on my PC I get blank screen or black screen. How can I fix this and which drive I need to install to eradicate this problem.
좋은 질문 입니까?
좋은 질문 입니까?
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
해당 답변은 도움이 되었습니까?
It dose not work cause when I tried to turn my screen it just blank can't see nothing
해당 답변은 도움이 되었습니까?
Try re-seating your video card and RAM modules and then try powering on the computer. Does the computer make any beep noises when it is turned on?
해당 답변은 도움이 되었습니까?
This just happened to me. Diagnosis was a blown power supply & blown capacitors on the motherboard. Got the power supply. Still looking for the motherboard...
해당 답변은 도움이 되었습니까?
Hi jayeff
Yes! it's exactly what I was looking for. Problem is I needed it by the end of the week! I found a refurbished one for $72 with a 90 day warranty & paid for 2nd day air shipping, at Discount Electronics in Texas. Should get here by Fri... Thank you for looking for me & posting the link. I appreciate it very much!
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 950
댓글 2개
Have you tried a different monitor? Have you tried your monitor on a different computer etc.? Does your PC sound like it is turning on?
oldturkey03 의
Iv tryed a different longer and it still want turn own my screen is blank can't see nothing
Ameerah Green 의
