주요 콘텐츠로 건너뛰기
Product released in 2011. Portable on-ear headphones that come with a detachable audio cable with built-in remote and mic for iPhone/iPod/iPad connections, and a carrying case.
22 질문 전체 보기
Why are my hinges loose on the headphones
My beats solo hd they fold when i move around they dont stay firm
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
blade6462, loose hinge pins can cause this. Remove the cover plate on each side and you will see how the pins are inserted. It is possible that either they are worn or the holes where the pins go through is starting to wear out. Sometimes you can fix this by replacing the pins with slightly larger ones.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Beats studio loses from left side hing is ok but hing connect to band from there its loses what i do now :(
댓글 달기
Like
i like beat
Like
i like beat
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
how do i fix this problem for my beats because i tried everything and nothing works.One side is opened!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
blade6462 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 26
전체 시간: 14,334
