주요 콘텐츠로 건너뛰기
The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
22 질문 전체 보기
I dropped my Xiaomi Mi 3 in water, what do I do?
My Xiaomi Mi 3 has come into contact with water, what should I do to ensure that it does not get permanently damages from water exposure?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
I am not skilful and due to lockdown all shops are closed what should I can do
댓글 달기
답변 4개
At this unfortunate situation, what you should NOT try to do after removing your phone from the liquid is to turn it on. If you do so, a short circuit may occur to your device taking the risk of having a permanent damage.
Wipe off the phone with a dry towel as best as possible. Remove any accessory on your phone such as phone cases and the SIM card. You can then use a hairdryer on COLD setting to dry the phone, and then put the phone in a warm area to dry for a day. Make sure your device is dry and attempt to power the phone on. If the phone cannot be powered on after being completely dried off then some of its components were likely damaged and the phone will require further inspection of its internal components to return the phone to operational condition.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@Michelle Deyongh, using hair dryer would only push the water more inside the phone by its air.
댓글 달기
Try drying your phone where the sun shines but not too much light and leave it for 5 days. Don’t try opening or restarting your phone until 5 days drying. Make sure no one disturbs it. Also remove the back case of your phone and Sim Card ( If you have some) before drying it out. Hope this would be helpful.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
First things first. Don’t turn you phone on as this can cause a short circuit. It’s important to get any water out of the device as soon as possible. Letting it sit around in a dry place makes sense but the problem with that is that there is probably still going to be some moister left inside the phone. What you really need to do is get the device opened up so you can be sure you get all the water out of the device and clean up any corrosion that may have started. If you don’t have the skill to open your device up yourself take it to a local repair shop that does water damage repairs.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
my method is get jar full of dry rice … switch off phone… sink phone into rice completely… wait 1-2 days… Dry rice is hygroscopic, meaning that it can pull moisture out. REGARDS
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi,
This link may be of interest to you.
Rice is for dinner not repair
댓글 달기
귀하의 답변을 추가하세요
Brian Cantler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 24
전체 시간: 17,842
