주요 콘텐츠로 건너뛰기
Apple의 휴대용 컴퓨터는 1999년에 소비자들을 위해 처음 공개되었습니다.
232 질문 전체 보기
What do I replace the original thermal materials with?
I am reinstalling my recently repaired logic board in my G3 900mhz iBook 14". The original thermal heat transfer materials on the heat sink were two preformed squares, the larger was a blue foam looking square, the other smaller one was gray and seemed to be a more solid version and consistency of thermal paste. Can I use the normal Arctic Silver paste for the installation or do I need to find the same type of original squares?
Thanks,
Randy
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
Good question +
Thank you, I'll give that a go.
Randy
댓글 달기
답변 1개
선택된 답변
Arctic Silver Thermal Paste will work great om the heat sink in your laptop.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks. Do you have a recommendation for the thickness of the paste? The iFixit instructions say to spread a thin layer. The original materials were fairly thick, maybe up to 1/16th of an inch.
My experience in the matter is that it's better to have a bit too much than a bit too little. You just really need to make sure you don't have any that comes out over the edges / spills out when you reapply the heat sink. 1/16 " sounds fine to me, I just like to make sure I can't see the processor any more through the thermal compound.
댓글 달기
귀하의 답변을 추가하세요
randy3833 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 2,230
