주요 콘텐츠로 건너뛰기
Guides for the Sony Vaio Tap 11 tablet. Announced on September 4, 2013 and released October 18th, 2013. Model number SVT112A2WL. The slim, sleek, and sexy cousin to the Surface Pro 2.
Why is my keyboard not connecting?
I've already tried charging my keyboard from the device battery, the battery shouldn't be the problem. It seemed to stop working after I updated to Windows 8.1. Any help?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 5개
선택된 해법
If the keyboard stopped working after 8.1 update. It is most likely due to the system settings have been reset. The problem is most likely the filter key function. To fix this, disable the filter key and restart the device. For more details please visit this Trouble Shooting Page .
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks! You really saved my bacon bits!
댓글 달기
가장 유용한 답변
Check in device manager to see if your keyboard drivers are installed, most likely Windows is struggling to find your drivers. Might be a good idea to go to the manufactures website and download and install the latest version of drivers.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Imybash Thanks. It worked. Best to update the BIOS first.then the keyboard driver https://esupport.sony.com
Select computer then the driver
이 답변이 도움이 되었나요?
점수 0
댓글 달기
@ Imybash Thanks! It worked
Updaed the BIOS first, then the driver
Enter your model
https://esupport.sony.com/US/p/select-sy...|type1_us_en|drivers
For SVT11213CXB
https://esupport.sony.com/US/p/model-hom...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Anyone owns TAP 11 should follow instructions below. (Tested with SVT112A2WM with Windows 10 x64 bit)
  • Click Pairing (YOU WON’T SEE A "Starting pairing (** seconds left)…….." MESSAGE AS SONY SUGGESTED. DON’T WORY AND CARRY ON AND PLEASE IGNORE ANY DIRECTIONS YOU SEE ON THE PAIRING TOOL MAIN WINDOW)
  • Turn OFF the wireless keyboard
  • Press CTRL + Esc
  • Turn ON the wireless keyboard
The battery light will flash and the Caps Lock light will flash 4 times and the keyboard will pair.
Credit belongs to Clea Jamerson
http://www.designstudioschool.com/sony-s...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alexander Bridges 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 27
전체 시간: 8,283
