주요 콘텐츠로 건너뛰기
VTech Baby’s Learning Laptop identified by model number 80-073800.
1 질문 전체 보기
질문 마감됨
Why does my device not turn on?
When the mode switch is moved from the off position, the laptop does not turn on. What can I do to fix this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Even I turn on it was working before but not turning on
댓글 달기
답변 2개
선택된 답변
The batteries may be low or dead from use/improper storage. If the problem continues after the batteries are replaced, check out our troubleshooting page to direct you to the proper guide.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Following causes may occur -
  1. charging issues
  2. perform a power cycle
  3. check your battery
  4. check the screen
  5. Use Your Computer to Troubleshoot
  6. reset your device
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 269
