Why is my trimmer not turning on?
I have not used my trimmer for a while and now it is now turning on. I already changed the battery but it still does not work.
좋은 질문입니까?
좋은 질문입니까?
Since you have not used your trimmer for some time, there is a good chance the battery or switch leads are corroded. Check out the troubleshooting page for more information.
이 답변이 도움이 되었나요?
WD-40
Mine ER-GN30 has always seemed to perform as though it has a low battery. I first noticed corrosion on the negative battery contact, the one up in the body of the unit. I treated it with Caig Deoxit D5 (an amazing product) which helped, yet the issue continued to return.
Recently, the trimmer stopped working all together. I used a power supply to "bump it" with 3v which got is spinning. So I know the switch is good and the motor "can" turn.
I removed the battery and pointed the trimmer blades toward the ground and then liberally sprayed WD-40 up into the body of the trimmer. I sprayed a lot, enough to completely saturate the internals. Then I tipped it over and used some compressed air to blow out any remaining fluid.
The trimmer once again works great, the blades spin at full speed again.
이 답변이 도움이 되었나요?
지난 24시간: 3
지난 7일: 19
지난 30일: 105
전체 시간: 20,071
댓글 5개
I bought the ER430 and it runs and then stops.
I cant figure out why this happens
marc101 의
I removed the top part and then the gear turned. When I put it back together it worked
expson1972 의
i took top off then clear out the opening in back below the cap that shows arrow to open aperture that had hairs in it. then it worked again.
Thomas Howard 의
WD-40!
I've had a Panasonic ER-GN30 nose hair trimmer for years, although I don't use it often and I'd say I take good care of it.
It has always seemed to perform as though it has a low battery. I first noticed corrosion on the negative battery contact, the one up in the body of the unit. I treated it with Caig Deoxit D5 (an amazing product) which helped, yet the issue continued to return.
mark mcatee 의
Can you please post the picture of Panasonic ER-GN30 Switch. After dismantling the same while fixing it one U shaped plastic clip fell off . I don’t know from where it was fixed. However my machine works fine even without that clip.
Ajit Kumar 의
