주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Charging keeps changing from 2% to 3% and then to 7%
The iphone 5s is with Sprint. It is having issues with charging, it cycles between 2%, 3% and 7%. It has been doing this for 2 days now. If the batteries dies and the phone turns off, it does not charge and stays on the battery with drained capacity icon. I have changed the battery but the problem persists. It may not be the charging port because when I unplug it, the drained battery icon changes to lighting and tip of the cable...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
It sounds like it possibly could be a problem with the U2 chip. This is a chip on the board that when it fails won't charge the battery specifically when the battery gets really low.
The failure can be caused by using non-Apple chargers.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Thank you James for the quick response!!
tnk james
my 5s have this problem too
댓글 달기
There are a few things you can try. To see if it's the u2 chip. However, if it is, you're probably going to want to send it to a quality repair shop. Like Jessa Jones
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you for the quick response!!
댓글 달기
Rule out bad battery and back dock connector. Then rule out FL11 missing gas gauge filter on the board near battery connector. If none of that solves, it is U2 charging logic ic.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Dear Jessa,
Thank you for the prompt response! FL11 is present and I checked for the continuity at FL11 near the battery connector next to C279, it checks out (the multimeter beeps). Just to make sure that is what you have implied.
댓글 달기
귀하의 답변을 추가하세요
Aashish Shrestha 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 106
