주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Moto G는 경제적인 가격의 Motorola 스마트폰입니다. 이 스마트폰은 사용자가 원하는 모든 기능을 갖추고 있으며, 가격은 절반 수준입니다. 모델 번호는 XT1032, XT1033 및 XT1036입니다.
Front camera connector locking tab loose
Hello,
While trying to replace my Motorola Moto G screen, I had to disconnect the front facing camera. Unfortunately, the locking tab came loose. I don't have any idea how to fix this... Could anyone help me?
This is a picture describing my problem: http://i.imgur.com/IjN96kg.jpg
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
I fixed the problem myself just by using Scotch tape. I didn't really tape the connector to the port to keep it in place, but I put 3 small layers of Scotch tape on top of the connector. Then I inserted the connector. It's not really easy to insert the connector because it got thicker, but that's the reason why it works: the thickness of the connector with the Scotch tape "simulates" the pressure of the locking tab.
TL;DR: put small pieces of tape on top of connector, then insert connector. Test front camera and add layer of tape if necessary until you reach suffising pressure.
Excuse me for my English and good luck to anyone with the same problem :) feel free to contact me if something isn't clear.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have had this happen a couple of times. As long as the tabs on either side of the "door" (black plastic piece that came loose) are intact and not broken off you can somewhat easily re-insert it. Try placing the door at a 90 degree angle and then gently swing it into place. Be careful not to bend the pins in the onboard connector though.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
Thanks! How can I see which side needs to be facing the pins and which side needs to be facing up?
의
Should be evident when you inspect the door. both sides will appear different. One should have obvious fluting that will seat around the pins on the connector.
의
I really can't get it in there though... Is there any way I could make it work without the lock?
의
Possibly by taping the connection. I definitely would not suggest it though. The door will go back on. As long as it is not damaged it just takes a little perseverance.
의
댓글 달기
hi, in my work i have this issue every day and my solution is reinsert the plastic seal... in 90º degrees but if i lose it, i put a little piece of other plastic like the original piece the funcion is the... same :) great hug from chile
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Wouter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 39
전체 시간: 571
