주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Not powering on with plugged in
Hi, I have a bit of an unusual one.
I have an iPhone 5c that isn't recognising the power cable when it’s powered off. If the phone is on everything works as normal, but if the phone is off, nothing.
I have tried different batteries and charging port to see if they have any affect with no success.
A bit of history, phone has had a screen replacement. No signs of moisture/water.
Original owner said they had always the apple wall plug but had used 3rd party usb cables.
My initial though is maybe a U2 ic but could do with some other input before I go down that path.
Any and all ideas welcome, thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Well, that is a possibility. However, when you hear hoofbeats, think horses, not zebras. I'll admit this sounds unusual. But, before going down the micro soldering path, try teplacing the Lightning dock. Here's parts
iPhone 5c Lightning Connector and Headphone Jack
Here's labor
iPhone 5c Lightning Connector Assembly Replacement
iPhone 5c Lightning Connector and Headphone Jack 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Thanks for your insight but I have already tested a new charging port with no success, also the charging port work normally once the phone is on.
Right. Have you tried a force restart?
How to Force Restart an iPhone 5
Or backing up the phone, and restoring to a backup?
Considering I have replaced the battery I don't think a hard restart will help. I will try a full restore once I get the original to remove the iCloud account from the phone.
댓글 달기
귀하의 답변을 추가하세요
Duncan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 91
