주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for laptops manufactured by ASUS.
2518 질문 전체 보기
Wi-Fi always stays off. How to enable?
Hi, my UX305FA (Win10) has this red X on its Wi-Fi symbol, it saids "Not connected - No connections are available" when mouse over. The wi-fi toggle in NETWORK & INTERNET settings always stay off. And the wifi device option is grey-out in the Airplane mode page. Network adaptor is enabled correctly in Device Manager. It seems like the wifi is disabled by some kind of hardware switch.
I have try booting into Ubuntu (by usb) to confirm. Problem remains, and the wifi message is "Wi-Fi is disabled by hardware switch" .
Does anyone know if there is any hardware Fn key on this laptop to enable the wifi? There is none that I can find. The only network related Fn key is the airplane mode Fn+F2.
Any suggestion?
Asus zenbook ux305FA
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 2개
For anyone having a problem with ASUS laptops, F5R specifically, I personally never noticed that I moved the _physical_ switch (rather than the Fn+F2 combo) on the left side of the notebook which hardware-locked the wifi. Curiously, on a cold start in Ubuntu/Elementary wifi works, but after a reboot it doesn't. F5R owners make sure to check that the switch is in on position.
thanks mate you saved me another hour of chasing my tail. Cheers
댓글 달기
답변 3개
선택된 답변
Hi,
According to the user manual in the BIOS area under the Security tab -- I/O Interface security there is a Wireless Network Interface option to lock or unlock. The manual shows it as unlock you might want to check and see if yours is in the lock position.
해당 답변은 도움이 되었습니까?
점수 2
댓글 13개:
It is in [Unlock] position.
hi,
can you turn airplane mode on and off using Fn F2?
Yes, airplane mode is functional.
Bluetooth is grey out when airplane mode is ON.
Wifi is grey out no matter what.
maybe you could try
make sure airplane mode is off
go into bios and "lock" wireless network save change, boot into Win check that WiFi is greyed out.
then go back into bios and unlock wireless network save change, boot into Win and check
basically toggle the setting
found this on the Asus website
http://www.asus.com/us/Notebooks/ASUS-ZE...
driver download for wireless - asus wireless don't know if this is yours -a driver to switch Airplane mode (wireless ) on/off dated 2015 /08/14
might be worth a look
댓글 8개 더보기
댓글 달기
Your wireless controller may be broken our have loose connection
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, I had the same problem.
I tried re-installing the WiFi driver. Still the same. My netbook is a dual boot seashell series. I opened the program with Asus Express Gate Cloud (firefox), went to settings , swithed the WiFi off & on & the WiFi switched back on. I was playing in this area a week or two before trying to get it to work & I must have switched the WiFi off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Fan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 31
30일 전: 123
전체 시간: 89,324
