Why is my battery life so short?
The battery life in my calculator keeps dying, even after I replaced the battery twice.
좋은 질문 입니까?
좋은 질문 입니까?
This may be a problem with the solar panel. The solar panel supplies charge to the battery, so if it is malfunctioning then it would make sense for the battery to die quickly. You should probably refer to the Solar Panel Replacement Guide.
해당 답변은 도움이 되었습니까?
1 stop overcharging
2 get a new cable
3 get a new block
4 use a lower amp charging block
5replace battery
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,419
댓글 1개
How long does it last for ?
miniarma 의
