주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-30 XS Multiview Solar Panel Replacement
필요한 것
    1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: 1 단계, 이미지 2개 중 1개 Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: 1 단계, 이미지 2개 중 2개
      • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
      • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
      • Use the spudger (or fingernail) to pry into the space between the blue back cover and the white body to take off the back cover.
      댓글 쓰기
    2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: 2 단계, 이미지 1개 중 1개
      • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
      • Lift the metal plate from the battery and set it to the side.
      댓글 쓰기
    3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: 3 단계, 이미지 1개 중 1개
      • Use the spudger (or fingernail) to lift the battery from the black holder.
      댓글 쓰기
      • Put the new CR2032 battery in. Never insert a different type of battery!
      • Make sure the positive side of your CR2032 is facing up.
      • Reverse the steps 2 and 1.
      댓글 쓰기
    1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: 5 단계, 이미지 1개 중 1개
      • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
      댓글 쓰기
    2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: 6 단계, 이미지 1개 중 1개
      • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
      • Carefully pull the solar panel away from the calculator, as shown to the left.
      댓글 쓰기
    3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: 7 단계, 이미지 1개 중 1개
      • The capacitor might not be discharged. Proceed with caution.
      • Unsolder the three wires from the motherboard.
      • Unsoldering help can be found here.
      • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Aaron Feinstein
회원 가입일: 10/01/15
401 평판
안내서 1개를 작성함
Cal Poly, Team 11-2, Forte Fall 2015 Cal Poly, Team 11-2, Forte Fall 2015 회원
CPSU-FORTE-F15S11G2
4 회원들
안내서 12개를 작성함
1가이드 댓글
Do you know where I could get a replacement solar panel for the calculator?
Josh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 42
전체 시간: 3,053
