Why won’t my Le Pan S charge when it’s plugged in?
My Le Pan S tablet will not turn on. I repeatedly hold the power button, and I still have a blank screen. When I plug it into the wall, nothing happens
좋은 질문 입니까?
좋은 질문 입니까?
Try plugging the charger into multiple outlets to make sure the issue does not reside within the electricity being supplied to the outlet. If you have no luck, consider using a friend’s charger or purchasing a new charger to charge your device. If the issue persists, the problem you are experiencing is most likely due to internal components such as a battery. Please see a troubleshooting page located at Le Pan S Troubleshooting.
해당 답변은 도움이 되었습니까?
After trying multiple solutions including purchasing new cords, pressing the reset button and other online fixes i resorted to opening ours when it refused to charge - i disconnected the battery and then reconnected it problem solved and the tablet works again
해당 답변은 도움이 되었습니까?
My lepan is in a different language.. how do I change language to English if I cant read the language it s in...bi
I have a new charger and I have never used this le pan its been sitting unused for years because we lost the charger then lost the l pan
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 2
30일 전: 10
전체 시간: 4,382
댓글 2개
My tablet won't stop deleting its like it stuck on deleting.
expressway691 의
the pad is not coming on when charging it
Patricia Banks 의
