주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
Touch screen not responding
My iPhone 5C fell off and the touch stopped working. There are no cracks, but sometimes you can see a brown (red?) grind pattern (image included). I found one topic connected with this problem and one member wrote:
I had this issue recently, where after a complete digitizer replacement, the phone turned on and looked great, but it no longer responded to touch and there was a strange grid pattern on the display. It turns out, under the adhesive piece that covered the digitizer's attachment to the main logic board, there was a tiny fuse that had fallen off. I am now looking for a micro repair place that can reflow this fuse back onto the main logic board. Make sure there isn't some other hardware damage.
Touch screen problems after screen replacement
Can anyone explain this to me? What can I do now? Can I see it (fuse) on some photo?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
선택된 해법
Yeah, it's an issue with your digitizer. You could try taking it off and putting it back on. It's a thing I do, when a new one isn't co-operating. If you try this and it doesn't work. Remove the cables, disconnect the battery, reconnect the battery, then reconnect the display cables
iPhone 5c Screen Replacement
Worst case scenario you could buy another one from here
iPhone 5c LCD and Digitizer
Replace a scratched or cracked front glass digitizer panel or malfunctioning 4.0 inch 640 x 1136 pixel IPS LCD compatible with the iPhone 5c. 이미지
제품
$39.99
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you, I will try to do everything you mentioned after I get some stuff (pentalobe screwdriver) and I will post the results.
댓글 달기
I have the same problem. Can you explain where is the fuse on the logic board and if the repair has worked ?
Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
iK0X 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 21
전체 시간: 1,271
