주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
F:01 error code when trying to wash clothes
What does F:01 error code mean?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Mac Jones, F01 is the code for a failed main relay power control board. If you remove the board, take a look and see if you have any obvious damage which might be repairable. Take a look at the wiring as well as the components and connectors, check for corrosion.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mac Jones 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 1,355
