주요 콘텐츠로 건너뛰기
다섯 번째 Google Nexus 휴대폰. 2013년 10월 31일에 공식 발표되었으며 4.95” 1080p 스크린, 2.26GHz Snapdragon 프로세서 및 LTE 지원을 자랑합니다. Android 4.4.2, KITKAT. 제조사는 LG.
222 질문 전체 보기
질문 마감됨
How to get isopropyl alcohol out of display
I recently took my nexus 5 phone in the sea by accident. Since then I soaked the device in fresh water, then disassembled, and soaked and brushed all the parts with isopropyl alcohol. The good news is it works again! However I still have some dark patches on the display. I think this is still fluid between the screen and the glass window.
I'm not sure if its water or alcohol, but I believe it is alcohol, because I completely dried the phone for a week before using the isopropyl. If it's alcohol in the window, should I use rice to dry it out, or just leave it exposed to air? Or perhaps use an oven on a low temperature? Its been 3 days now, and the fluid has reduced, but it is still a big problem.
Thanks for your help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
James Barber don't even think about rice. It is not working, never will and never has. Isopropyl in the higher concentration (90%+) should already have been evaporated. The residue may be from the initial salt water exposure. You can try and see if a low temperature decrease the size of this. Otherwise you might be stuck with that. Not a bad result after having been water damaged.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 148
