주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DigiLand DL1010Q는 2014년 하반기 유럽에서 출시되었습니다. 이 기기는 Android 5.1 운영 체제를 사용합니다.
Why won't it hold charge?
I fully charged my DigiLand DL1010Q but the batter only lasts for a short amount of time. My device used to hold charge for hours upon hours, and now it only lasts an hour, if that.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
any idea where i can buy a replacement charging port? thanks
의
I have 2 Digiland DL1010Q one of my tablet is no good because it was a battery and won't charge. And the other tablet is on and off do you have any information that can help fix Digiland DL1010Q to replacement charging port?
의
Digiland DL1010Q tablet is not charged because the battery is no good i want to get it fixed but I don't know how.
의
댓글 달기
답변 2개
선택된 해법
If the battery will not hold charge, generally this means the batter is no good. Don't worry though, this is an easy fix. For more information go to the DigiLand DL1010Q Troubleshooting Page!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have Digiland DL1010Q tablet it won't charged and battery is no good do you have any information that can help fix the battery replacement charging port?
의
댓글 달기
@michaeleason, if you check the device page, there is a guide there for replacing the battery.
DigiLand DL1010Q Battery Replacement - iFixit Repair Guide
Be aware that the battery wires are soldered onto the motherboard, so you will need a soldering iron to do this repair.
I do have one criticism of that guide; their technique for removing the battery is unsafe and can result in the battery catching fire or possibly even exploding. I would suggest flowing some 90% or higher concentration isopropyl (rubbing) alcohol under the battery and let it soak in. Use dental floss to saw through the adhesive under the battery, adding alcohol as needed. Avoid bending the battery if at all possible; you should be able to get it loose with this method without damage.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Faith Lebo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 27
전체 시간: 1,715
