주요 콘텐츠로 건너뛰기
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
iPad Air Shadow/ waves left side
Hello,
i have an iPad Air 1 Gen LTE 16GB.
I bought it on eBay with an cracked digitizer and LCD.
After replacement there are some shadows/ waves on the left side.
What is this?
The old cracked screen had this also before..
It works pretty well with iTunes no other problems but it look´s horrible..
Does anyone know how to fix this?
Thank you so much for your help! I love this Community!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
So this is appearing on the new lcd that you installed?
Thank you so much for your answer.
SMD Soldering should be possible but i need the new parts.. and how can i identify the dead filters on the mainboard?
댓글 달기
답변 1개
가장 유용한 답변
Looks like a backlight issue. If it is appearing on both the old and new LCD then it must be an issue on the logic board (backlight filter perhaps) which will require board level repair.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you so much for your answer. SMD Soldering should be possible but i need the new parts.. and how can i identify the dead filters on the mainboard?
Any suggestions if it's only happening on the left side?
댓글 달기
답변을 추가하세요
Christian Wolfram 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 16
전체 시간: 1,573
