주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
561 질문 전체 보기
질문 마감됨
Water damage, Strange GPU issue
Hello,
I had a Macbook Pro without a backlight issue and I asked for help here
Water spillage no backlight, fused fuse?
Now I managed to solder another LCD connector and the backlight is back. The problem is now I'm having a strange GPU issue.
Whenever there is a change between the discreet GPU and the integrated GPU my Macbook freezes and won't work unless I reboot it. For example, I turn it on and everything works until I open for example, iPhoto or Spotify or Chrome. The other way around also happens, if I turn the macbook on with an external monitor plugged they'll work fine until I unplug the external monitor. In that moment the macbook will freeze.
Has anyone experienced this issue? It's clearly something to do with the switching mechanism!.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Does someone have the schematic of this board? It's clearly a hardware issue that the switching is failing.
I downloaded the schematics but I'm overwhelmed by this. I have actually no idea where to start testing. I know the switch between iGPU and GPU is failing but no clue as to where this is in hardware
댓글 달기
답변 1개
That sounds very strange indeed!
Would you be willing to attempt a windows bootcamp or booting a system on a usb to try and see if switching works in a different OS?
It sounds like a driver problem rather than a hardware problem because of no other problems than the lcd.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It's not a driver issue. I took it to Apple and they were unable to run the VST test as the screen suddenly goes black. Another example is, whenever I format the OS, I NEED another screen plugged into the HDMI as the internal screen doesn't show anything until the installation is complete. Very weird indeed.
The problem is that the mac is useless in this state, I'm unable to do anything that requires a little bit more of power
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 173
