주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
질문 마감됨
Ram up to 6G?
Can this computer go up to 6G of ram? If so how do I install it?
thanks,
Brian
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Hi, If you would pick your Model MBP from the chart in my link and let us know how much memory you need we will link you to installation instructions. (It could be as little as 2 GB or as much as 6 GB depending on Model)
http://www.everymac.com/systems/by_capab...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
As far as i know 3GB is the max.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
A1226, I currently have 4G of Ram two 2G, but this site says that you can actually put as much as 6G of Ram on this computer by running a 4G and a 2G. My question would be, if this is true, which slot do you put the 4G chip into.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have just attempted to upgrade my MacBook pro4,1 (the lower case has been acts he'd so I can't read the model number), I have 2 x 2Gb SO-DIMM, however if I install both of them the machine doesn't boot. If I install eather stick along with one of the original 1 Gb sticks it boots. I have tried all combinations of RAM sticks in every slot... So long as there is no more than 3 Gb the machine boots.
Is there a trick to get it to work with 4 Gb (2 x 2Gb) installed?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
First, please start a new question. Second we need to know exactly which machine you have. Please look in the battery compartment and give us the last three figures of your serial number. Thanks
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 4,481
