Why is my xperia z1 had a network problem?
Sometimes, network in my device working as usual. And then, it suddenly change it into "Emergency call only". After that, it has a network back. And then, disappear. It repeatedly every second.
좋은 질문 입니까?
좋은 질문 입니까?
The Sony phone will show "Emergency call only" when the signal is bad. May be you are in the bad reception area. If not, check if the SIM has problem or the SIM card reader is loose.
해당 답변은 도움이 되었습니까?
The problem is of SIM Card slot I am also having the same problem.
But don't know how to repair it.
Any ideas?
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 3,741
Hi,
Try the following.
1. Remove SIM card and reinstall, see how it performs. If still the same,
can you put the SIM card in another phone that is on the same network and see if problem is still there? This will prove whether it is network or phone.
jayeff 의
