Why does document scanning produce a grey haze over the printed copy
When I scan or copy anything the resulting document is printed with a grey haze or hue to all the white areas
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Clean the scanner glass and the inner side of the document cover with a soft, lint-free cloth (microfiber is recommended), moistened with a little glass cleaner. If you see lines in your scans or copies, clean the left side of the glass carefully.
Caution: Do not spray glass cleaner directly on the glass and do not press the glass surface with
any force.
Here is a link which shows what to do (not your model but idea is same for all) http://printscan.about.com/od/howto/ss/c...
Here is a link to the user manual for your model, scroll to page 219-220 to view area to clean. https://files.support.epson.com/pdf/wf25...
해당 답변은 도움이 되었습니까?
you have the density set to a positive number , anything but pure white is then interpreted as pale blue or grey
해당 답변은 도움이 되었습니까?
Density set to -3 helped a lot. Density is under: Print, Properties, Advanced, Other Print Options
24 시간 전: 2
7일 전: 8
30일 전: 32
전체 시간: 10,221
