주요 콘텐츠로 건너뛰기
The Philips Norelco Shaver 3100 is an all-in-one styling trimmer. It has multiple attachments for all your grooming needs. It is identified by model number QG3330/60.
7 질문 전체 보기
What is the easiest way to clean the trimmer?
The trimmer sometimes gets hair stuck in the blades and doesn't work as well. What is the easiest way to clean the device quickly?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
The easiest way to clean the trimmer would be to rinse it under a faucet. The trimmer is water resistant, so it won't be damaged by water. For more information, visit the Philips Norelco MultiGroom 3100 Troubleshooting Page.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have found that rinsing with water is quick and easy, but water has its risks. One, the cutters are made of steel and water can corrode them (rust or mineral deposits). Two, water could possibly leak into the electrical part of the shaver. A good brushing with an old toothbrush, plus occasional alcohol cleaning, and spray lubricant or light oil will preserve shavers. I find the foil shavers take more time to clean than rotary shavers, but they give a slightly closer shave.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Another way my husband does it is by taking a soft bristle brush and brush off the hair off of it.
That works well to.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I too have this problem!
i feel the esiest is to have a trimmer head that is divadable by two, so you can pop the trimmer"hood" and fix the problem, - for me, a mothboll of hair has been growing on the farside & is putting a real strain on the engine of the trimmer-blades..
so..i guess i try the alcohol thing before i go breaking in.. thanks Bob
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi Krille, were you able to break open the trimmer head? Could you let me know how you did so?
댓글 달기
답변을 추가하세요
ahaharevolution 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 50
전체 시간: 20,410
