주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toyota Camry XV20 시리즈는 Toyota의 6세대 Camry 세단입니다.
Why won't my car start?
My 1999 Toyota Camry won't start, sometimes it will if I tap on the starter and press on the gas as I turn the key. Could my starter need replaced or my fuel pump?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Kaitie Richards does it make any noise when you try to start it? Does the engine turn over? When you turn your headlights on and try to start your Camry, do the lights go dim? What engine size does your Camry have and is it automatic or standard transmission?
댓글 달기
답변 5개
선택된 해법
This may be too late but...
I had this problem with my 1999 Camry and it turned out to be a bad starter motor. At first tapping on it would allow me to start the car but after a while it'd take more and more until at one point it just stopped starting period.
If this turns out to be your problem it's a pretty cheap and simple fix to do yourself for the most part: pick up a starter at O'Reillys , pop the old one out and the new one in. It was pretty straightforward so I didn't use a guide or video but this video seems to be a good start.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
never pump the gas pedal on a fuel injected car when trying to start it
이 답변이 도움이 되었나요?
점수 2
댓글 달기
If tapping on the starter gets it going then yes you need a new starter heres how to do it
https://www.youtube.com/watch?v=YOAm-qtI...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Turn the key to the "on" position without trying to start it, you should hear the fuel pump run for a few seconds then stop. Also you could pick up a cheap fuel pressure tester at an auto parts store and attach it to the valve on your fuel rail to get a true reading.
Do you have a multimeter? Check the battery to make sure it is reading at least 12V DC, the value should go up to about 13-14V once the engine is started, that lets you know the alternator is charging up the battery correctly.
When you say you "tap on the starter" are you crawling under the car and hitting the starter motor/solenoid? If you are and it works, it a good sign that the starter solenoid and/or starter is bad and sticking.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Everything in the car turns on and when I go to turn it on it makes a clicking sound when I try to turn it on but it won’t start
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
juan zuniga - may want to make sure the battery positive and ground cables are mounted securely on the battery.
댓글 달기
답변을 추가하세요
Kaitie Richards 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 34
전체 시간: 7,220
