Released May 1, 2012. The first backlit eReader tablet emits a soft backlight for improved night reading. The device is simple to open up, but the components are all connected.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Probably. If you can open your device so that you can see the port and then search on Ebay for micro usb port. Then match up yours to one of the many different styles available. They are all quite cheap. Then its a case of unsoldering yours and soldering on the new one. Thats what I would do. If you don't think you have the equipment to do that scale of soldering then a local phone repair shop should be able to help you out.
martin nash 의
