주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z3 Compact는 2014년 9월에 출시되었습니다.
Lower Loudspeaker doesn't work
Hi there, after the LCD replacement the lower loudspeaker seems not working anymore (also if replaced, so I think the problem is not the speaker itself but maybe is missing the connection between it and the MOBO). How is it connected to the MOBO? Maybe trough the black plastic bezel which contains the screws? It is broken in the left side, it fits good but maybe this is the problem that cause the malfunction?
Waiting 4 your kind reply
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Hi Maria
Did you solve the issue with lower speaker?
I have the same problem after replacing lcd
의 공유
댓글 달기
답변 2개
I will think the loudspeaker wasnt install correctly can you take a picture if you can.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It is already installed in the replacements lcd I bought
의 공유
댓글 달기
Hello. I know that I write after a long time I just would like your help.
I have the same problem with the bottom sound, after replacing the battery, and while I did not cause any damage, it does not work at all at the bottom.
Have you solved this problem?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Maria Aurora 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 14
전체 시간: 1,313
