주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
메시징과 음성 통화에 적합한 간단한 휴대전화로, 인터넷 접속도 가능합니다. ZTE에서 제조하였으며 2011년 8월에 출시되었습니다.
no sound with text message alert
Why won't my phone sound with text and message alerts?
It rings fine
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
No did not workI will take it to telstra store A big thank you for all your help. I am a fireman and all fire alerts come in a text form,as to why I need ring tone
의
very help full
의
A fireman turning out by phone ? You mean your in the bush fire brigade , not a professional firefighter.
의
댓글 달기
답변 3개
선택된 해법
Hi,
To change the incoming message tone go to:
Menu > Settings > arrow right to Profiles > Edit > Message Tone
There are a lot of other personalisations that you can change in Profiles > Edit e.g. Voicecall ringtone, Silent, Keypad volume, Keypad sounds, Ringing Type
Update (12/17/2016)
Hi @Vern Smith,
I cannot find a T93 listed on the ZTE website, but here are the procedures for a T930 and a T90.
As you can see they are virtually the same and are similar to the T95.
Perhaps arrow right means to swipe right.
T930
Click on image to enlarge it for better viewing
이미지
T90
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Hi @ Vern Smith,
To personalize your Message notifications:
Open the Message app, then tap the Options soft key ( usually the right hand side key of the 3 soft keys below the screen) then select Settings > Notifications then choose which options you wish to enable, disable and alter.
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
done that it works when I choose the tune but when I text from another phone no tune but the text comes through
의
Hi,
Do you get a notification at the top of the screen when a message comes in? Have you checked in Menu > Settings > Sound to ensure that the volume level for Notifications is set loud enough
의
I have no arrow right to profiles>edit>message tone I use a t93 phone.
의
sorry mate it a t83 telstra dave phone
의
yes, volume set as high as it will go
의
댓글 1개 더보기
댓글 달기
Try this:
Settings>Apps>Messaging and make sure “Show silently” is not turned on. This worked for the same issue on the ZTE Z835. I hope that helps you and any others who may have this same issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Earl Baker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 17,951
